meshing very fine only at decided area
    • Gijoys4v
      Dear Ansys,
    • Wenlong
      Hi Gijoys4v,
      I would try:
      1) Split the geometry into 2 parts, one is the region you want a very small mesh, and the section part is the remaining geometry. Then apply a bonded contact between them. This would be the case of your image since you don't have common nodes on the two regions' boundaries.
      2) Use adaptive meshing, assign a very small element size to the middle region, and relatively coarse mesh at the remaining region. Adaptive mesh setting is available under mesh settings. But this won't provide exactly the same mesh as you show.
      Wenlong
    • Gijoys4v
      Hi Mr. Wenlong
      Thanks for the reply. Is there any problem in the step you mentioned, if it(the model) is a for layered thin sheet
    • Gijoys4v
      Hi Mr. Wenlong
      can you check this link too
      /forum/forums/topic/mesh-control-2/
    • Wenlong
      Hi Gijoys4v,
      I don't see a restriction of modeling a layered sheet.
      Regarding the second question, since it is a different topic, could you please open a new thread, and provide more information, like the material properties, the model set up, numerical settings and so on. Only then can I provide meaningful suggestions other than wild guess.
      Thanks!
      Wenlong
    • Chinmay
      In my opinion, you should check face split option in tools of Design modular. You can check videos on YT for the same. It helped me refining mesh in a particular region with default mesh on other parts of the object.
      Thanks and Regards,
      Chinmay
Viewing 5 reply threads
  • The topic ‘meshing very fine only at decided area’ is closed to new replies.
