September 26, 2023 at 2:04 pm
Sungmin Yoon
SubscriberHello,
I bumbed a problem while I'm trying to make a stack structure and trying to monitor surface J Flux.
I have no idea.. It would be really thankful if you can help me.
Thanks,
Sungmin.
- assigned matetials to each layers
- set simulation region to contain all the layers.
- monitor type in 'monitor_1' is 'linear z'
- no warnings
while "Check" in "CHARGE" tab.
September 27, 2023 at 1:18 am
Dev
Ansys EmployeeHello, this post was closed. Have you solved the issue? Please confirm.
Thanks and regards
Devika
September 27, 2023 at 3:34 am
Sungmin Yoon
SubscriberFirst of all, thank you for your kind reply.
Fortunately, It was due to my slow labtop – finally I was able to see result on my desktop.
(So I tried to delete the post but there wasn’t a button, so I closed post.)
Thanks,
Sungmin.
September 27, 2023 at 1:11 pm
Dev
Ansys EmployeeThank you for confirming.
I am glad to hear the issue is resolved.
Another person who has a similar problem will find the content useful. That is one of the reasons there isn't a delete option. Thank you for using the forum, and please keep asking questions here.
I am closing this post.Regards
Devika
- The topic ‘Meshing stops at 5%’ is closed to new replies.
6435
