Preprocessing
Preprocessing
Meshing solid and fluidin fluent
    • lafo226
      I would like to create a 2d mesh that is a fluid domain, and include a nozzle. Obviously the nozzle is solid while the fluid domain is liquid. What is the best way to mesh this? I have been trying to create two seperate surface bodies using add frozen, and then in meshing, mesh them seperately. However, I become lost when dealing with the connections and contact surfaces. Could someone help me out with either how to mesh this, or a resource on how the contact surfaces work?
      Thanks!
    • Kalyan Goparaju
      Is there a specific reason for including a solid mesh in your simulation? If you are not intending to perform any fluid-solid heat transfer studies, you don't have to include the solid. Here are a couple of public videos on nozzle fluid flow analysis Ansys software.
      https://www.youtube.com/watch?v=oY_3_c0rDiw
      https://www.youtube.com/watch?v=P_jdywkbRQ4
      Thanks,
      Kalyan
    • lafo226
      Kalyan,
      The first video was very helpful and made a lot of sense. I had a follow up question. Once in fluent, how do I set regions to include different species? For example, I want the area near the nozzle to have all the species involved in the nozzle flow, but I would like there to also be ambient air in other regions of the domain.
      Thanks!
    • Kalyan Goparaju
      Fluent has an operation called patch that you can use to do what you were describing. Here is a link to its description.
      https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v201/en/flu_ug/flu_ug_sec_patch.html?q=patch
      Thank you,
      Kalyan
    • lafo226
      Kalyan, thanks for the quick reply. I am an academic student and cannot access that link.
    • Kalyan Goparaju
      Please see this post below on accessing help manuals when using the student version.
      Thanks,
      Kalyan
Viewing 5 reply threads
  • The topic ‘Meshing solid and fluidin fluent’ is closed to new replies.
