Meshing problem, I’ve tried a lot of ways to fix the error but nothing works, any suggestion to fix?
June 14, 2019 at 3:06 pm
PedroP
SubscriberHello, I am having some problem in generating a mesh for a personal project. I tried to decrease the elements size, to do a multizone mesh, to change the smoothering, but nothing works, and the main problem here is in regard to the enclosure. I can't decrease more my elements size. Do you have any suggestion for the problem? The first error is from geometry and the second is the mesh.
I also tried to mesh a raw geometry but there is the enclosure error yet... I attached the settings i've used (Multizone and Mesh) and the simplified geometry (despite having a lot of parts missing and raw geometry it's not complete).
Thanks in advance Â
Pedro -
June 17, 2019 at 11:04 am
Forum ModeratorPlease can you add the images into the text: staff are not allowed to download attachments.Â
June 24, 2019 at 1:44 pm
PedroP
SubscriberÂ
The main error is the enclosure error, in the last ones photos I tried to simplify my model at maximum, but the error in the enclosure is still happening and I can't proceed to another stage. In the full model (not simplified) I have two parts with geometry errors, but I can get rid of this parts - if necessary - to proceed. I have also tried to decrease at 1 mm the elements size but it is the maximum, once the pc has 16GB of ram and SSD.
June 25, 2019 at 6:22 am
DrAmine
Ansys EmployeePlease can you add the images into the text: staff are not allowed to download attachments / go to external links.
- The topic ‘Meshing problem, I’ve tried a lot of ways to fix the error but nothing works, any suggestion to fix?’ is closed to new replies.
1890
1419
