Meshing problem in explicit dynamic
    • george10
       Hey,
      Since i do research hip prosthesis forming in explicit dynamic, i find the problem which i cant define what the solution is. Some elements meshing soared up. When i check the quality of meshing on that elements, its still in average points( not lower than average). The contact is frictional, but when i change the contact into frictionless it still happen. My input force on die is 3000MN and prevelocity in 15 mm/s. can you help me why it could happen? i will attach the picture. i use istropic (young modulus and poisson ratio), density, and johnsoncook
      Please use the Insert Image button to put the image into the post as well as attaching it because ANSYS staff are not permitted to open attachments.
  • The topic ‘Meshing problem in explicit dynamic’ is closed to new replies.
