October 21, 2024 at 9:13 am
October 21, 2024 at 12:39 pm
Forum ModeratorWhat have you set the various sizing options as? Why do you need a butterfly mesh?Â
October 23, 2024 at 6:37 am
abhishekkumar2r0
SubscriberThe model is of CFD and it is hollow cylinder and fluid part is divided into 5 parts to creat uniform hexahedral meshing. I had done automatic method for the whole body and edge sizing of the edges dividing the fluid domain by choosing number of division as 100. And the result I am getting is in one sliced part of fluid domain long elements are formed instead of small ones. So how to resolve this or this can be solved as I am solving it for natural convection process when the tube is heated with a constant heat flux and nusselt number is to be calculatedÂ
October 23, 2024 at 10:30 am
Forum ModeratorI'm aware of what a O-grid/butterfly mesh is, I'm just wondering why anyone would bother doing it now.Â
You've set a cell size on the centre body. Have you set any sizing on the surrounding bodies? I'd favour using a single volume, inflate the boundary (read up on Sweep method) and pave the end face. It's far quicker and will likely result in a higher quality mesh.Â
November 29, 2024 at 7:57 am
abhishekkumar2r0
SubscriberHey Rob
Can you suggest me some methods with which I can increase element quality aspect ratio skewness without opting for o-grid technique to do a structured mesh.
November 29, 2024 at 8:03 am
abhishekkumar2r0
SubscriberAnd what metrics display should I follow for simulation in fluentÂ
November 29, 2024 at 10:05 am
Forum ModeratorOn a circle? No, there's a reason for pave mesh and decomposition.Â
November 29, 2024 at 11:38 am
abhishekkumar2r0
SubscriberYes on the circle so that I can get a structured mesh without going for o gird method
November 29, 2024 at 11:50 am
Forum ModeratorHow do you propose putting a square into a circle without either decomposition or very skew cells?Â
November 29, 2024 at 11:55 am
abhishekkumar2r0
SubscriberJust followed you tube videos to create this mesh
November 29, 2024 at 12:12 pm
Forum ModeratorHave you done the courses/lectures and tutorials available in Help?Â
5874
1306
