Electronics
Electronics
Meshing Problem
    • Shreya Guruprasad
      Hello All,
                    I wanted to know the best way to resolve the error "The quality of some mesh elements in not acceptable for solution. Please check the geometry for issues in the following location (in meters): X=0.321535, Y=-0.1189, Z=0.114.535."
    • Jason Kalogeropoulos
      Hello Shreya,
      Thank you for reaching out to Ansys Learning Forum.
      Please, make sure that in your design there are no invalid interesctions and missalignments. Also, I highly recomend using model units and extend of those apropriate, in order to capture any little detail that your model might have.
      Also, keep in mind that you can always use mesh seeding techniques (such as model resolution, surface approximation etc.) in order to mitigate any mesh flaws that occur due to object inconsistencies. In order to capture those faluty entities, you can always see Mesh feedback (Right click mesh>View mesh feedback).
      Kind regards,
      Jason.
    • poonamchnd23
      Hello Shreya, I am facing the similar problem with my Ansys Maxwell model. How did you solve the error?? can you please tell me regarding this.
  • The topic ‘Meshing Problem’ is closed to new replies.
