June 24, 2020 at 2:41 pm
abdulrahman86
Hi
I am trying to model a solid long building inside a fluid domain, I saw in a previous post an answer from peteroznewman to improve the meshing for such geometries inÂ
/forum/forums/topic/reduce-mesh-skewness-for-an-isolated-generic-building/
I tried to create the same concept, but it didn't work well for me as the quality measures are very low in all aspects
My model is a large one and I am trying to have smaller elements around the body and larger ones far away with the small number of mesh as possible to maintain a reasonable solution time. The meshing file is attached and it will be appreciated if someone can check it for me.
Thanks
June 25, 2020 at 3:35 am
Keyur Kanade
Ansys EmployeeAs ANSYS Staff, we can not download attachments. Please insert images using insert image functionality.Â
You will have to use different sizing functions.Â
Please have a look atÂ
https://www.youtube.com/watch?v=w4q6q8nKF3U
Also please go through help document on sizing.Â
Keyur
If this helps, please mark this post as 'Is Solution' to help others.
June 25, 2020 at 1:24 pm
abdulrahman86
Thank you for your answer, but I don't think that answers my question. I will post some pictures for my mesh
Currently I am trying two approaches, 1st using surface slice and edge sizing and the other one using the global mesh and face meshing all the faces of the objectÂ
The other method I am trying usingÂ
Many thanks
June 26, 2020 at 5:58 am
Keyur Kanade
Ansys EmployeePlease use patch confirming tetrahedron method.Â
Please use face sizing.Â
Also check body of influence. Define BOI.Â
Please checkÂ
/forum/forums/topic/body-of-influence-for-sizing/
Keyur
June 26, 2020 at 7:32 am
abdulrahman86
SubscriberThank you that increased the quality significantly.
For such geometry with fluid domain of 1300Â x 750 x 350 m and a building of 30 x 45 x 182 m
what do you suggest for sizingÂ
I chose Global 30 m, BOI 10 m, face meshing 1 m and got around 1.1 million cellsÂ
is that enough or too low as in the solver I am getting the turbulent viscosity limit issue of 200K cellsÂ
June 26, 2020 at 11:00 am
Forum ModeratorIt depends, are you resolving the flow gradients?
June 26, 2020 at 11:07 am
abdulrahman86
SubscriberI am not quite sure about the meaning of flow gradients. however, I am interested in the pressure on the surfaces due to the wind and the drag coefficient for validation
- The topic ‘Meshing of a building inside a domain’ is closed to new replies.
3647
1313
1142
1075
1013
