Meshing of 3D stepped cylindrical geometry
    • snr1
      How to change the number of elements along the axial direction of the stepped cylinder during meshing?
      It depends. Which meshing tool are you using?
    • snr1
      I am using the default ANSYS Fluent meshing tool.
      OK. You'll need to do some decomposition and/or use Multibody sweep as the normal sweep tool will struggle. Click on Help as it'll be covered in some of the tutorials.
  • The topic ‘Meshing of 3D stepped cylindrical geometry’ is closed to new replies.
