August 3, 2020 at 3:14 am
prajput
Meshing issues an error/warning message: One or more objects may have lost some scoping attachments during the geometry update. What does this warning mean and how can I address it?
August 3, 2020 at 3:28 am
Keyur Kanade
Ansys EmployeeUsually, it means that some mesh controls - like the controls that set the surfaces for inflation - may not be applying to the same surfaces as before.  It is a note that the associations for mesh controls should be reviewed. (Usually, some surfaces get dropped because their internal nomenclature has changed.) -
August 3, 2020 at 7:38 am
prajput
What Can I do to avoid it?
August 3, 2020 at 10:13 am
Keyur Kanade
Ansys EmployeeYou can try and turn associativity on on your model and see if that helps. The option can be found on workbench page, right click on geometry> Properties> Advance Properties> Compare Parts on Update> Associatively
More info at:
https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v195/ref_cad/cadComparePartsOnUpdate.html -
August 3, 2020 at 10:38 am
prajput
Can I make this option default so that I don't have to change it everytime I create a new geometry? Also are there any downsides of making it default?
August 3, 2020 at 10:55 am
Karthik Remella
AdministratorYes. change it as follows:
Workbench>Tools>Options>Geometry Import> Compare Parts on Update> Associatively
Downside of this would be more import times as compared to default option where this is off.
Viewing 5 reply threads
- The topic ‘Meshing issues an error/warning message: One or more objects may have lost some scoping attachments’ is closed to new replies.
Ansys Innovation Space
1208
1092
1068
952
