July 4, 2025 at 2:47 pm
ah3616
SubscriberI am trying to mesh my step file and have never had issues with the boundary nodes connecting until now. I am using the same mesh size as before but for some reason the nodes at the boundary of the parts are not lning up. I am using auto mesh (size based), mixed mesh elements, and have tried selecting connect boundary nodes and not. I have also tried meshing the parts in the opposite order. I did not have any issues with thos before.Â
July 4, 2025 at 3:48 pm
Dennis Chen
Subscriberare you using lsprepost?  I would suggest looking into a different preprocessor.  Lining up mesh and node merging is a ton easier inside workbench ls-dyna which is borrowing the mesher from Ansys.  you can do shared topology in Ansys's geometry tool or direct node move/merge in the preprocessor.
3442
1057
1051
917
896
