August 27, 2018 at 11:07 am
August 27, 2018 at 11:20 am
Naresh Patre
Ansys EmployeeHello Abhay,
I see that you have specified Mapped Face Meshing. Try suppressing it and regenerate the mesh.
Also, first try to generate mesh with default global mesh settings. Once the mesh is generated, you can modify and/or add local settings to improve the mesh as required.
August 27, 2018 at 11:27 am
abhay mahar
Subscribersir i just generated meshing with default settings . but it did not worked
then i meshed it with faced meshing but it also did not worked
August 27, 2018 at 11:29 am
abhay mahar
Hello Abhay,
sir these are two regions where meshing is not working properly . i tried default settings at first but it did not work
- The topic ‘meshing is not properly working’ is closed to new replies.
- Add-in Error Excel
- Spaceclaim problem
- Different Body Naming and Extra Surfaces after Importing Solid Edge Part
- New Computer
- Inconsistent Script
- MISSING SIMULATION SECTION/RIBBONTAP
- Unable to attach to geometry file 2025R2
- How would I select specific components and all bodies under it?
4628
1535
1386
1215
g.jpg?width=690&upscale=false)
