July 14, 2023 at 10:36 pm
Lumisade Snow
SubscriberHi all, I am trying to model fluid flow across a perforated plate of hole size order 10^-1 mm, but meshing is taking extremely long, like more than 12 hours... Is it normal? Or it there a faster way? Like I want to see the fluid strucutre interaction that occurs when fluid flows through the holes. Many thanks in advance!
July 17, 2023 at 8:53 am
Forum ModeratorIt's not, but I don't know what the hole size is relative to the domain. An 0.1mm hole will want 15 or so cells across to get the flow field right, but if your domain is at the cm scale the cell count could be rather large. Similarly, if you use too many local sizing constraints the mesher will need to work out how to meet all of these requirements.Â
- The topic ‘Meshing for a micro-perforated plate’ is closed to new replies.
1565
1386
1242
