October 22, 2024 at 10:23 pm
hbwansapura
SubscriberWhen I try to mesh my geometry, there are warning messages saying "One or more faces with map mesh controls failed to be mapped mesh" and the top right mesh doesn't work. I tried to mesh the face and edges separately, removed the bias, checked for edge errors, turned off the Check Mesh Quality setting and updated the mesh and it still didn't work.
October 23, 2024 at 9:09 am
Forum ModeratorThe more edge settings you use the more likely you'll accidentally have a discrepancy on one or more ends of a surface. I'd tend to look at a good inflation mesh around the airfoil and then use pave to the far field. That also avoids all of the high aspect ratio cells or jumps in cell size between faces.Â
