February 24, 2023 at 5:59 am
February 24, 2023 at 10:52 am
Aniket Chavan
Forum Moderator-
February 25, 2023 at 6:53 am
Mit.Shah
SubscriberYes, I am using the stand alone Fluent Meshing
February 24, 2023 at 10:53 am
mjmiddle
Ansys EmployeeHello Mit,
What application are you using? Share topology is not done as part of the mesher. This is done inside SpaceClaim or DesignModeler. SpaceClaim has a built-in mesher which is a more advance multizone, but otherwise the geometry is usually transferred to the Meshing Application or Mechanical inside workbench for meshing (there are a few other choices on where to mesh and transfer from there).
I am not familiar to this error, but the term "platform" refers to the operating system, such as Windows 10, 11, Linux Red Hat Enterprise 7, 8 , etc... The following page shows supported operating systems per application for Ansys 2023 R1 products:
https://www.ansys.com/content/dam/it-solutions/platform-support/ansys-2023-r1-platform-support-by-application.pdf
I see a mention of the unbound variable error in Fluent knowledgebase solution 2041270:
Check to see if you have the below variable defined. If not, please define it.
LANG = en_US
or
LANG = C
This issue has been seen with :
RHEL 6.7 machine
German languageÂ
February 25, 2023 at 6:58 am
Mit.Shah
SubscriberHi Mj,
Fluent Meshing allows us to apply share topology as a part of its Watetight geometry workflow. I doubt the term here refers to the OS because I have always worked in the same OS system and haven't encountered such a problem.Â
February 25, 2023 at 9:34 am
mjmiddle
Ansys EmployeeI work with Mechanical products, so sorry that I was not familar with the Fluent error. The knowledgebase solution applies to Fluent, however. Did setting the LANG help?
- The topic ‘Meshing error for Unbound variable’ is closed to new replies.
5884
1306
