Meshing Error
    • wanhaf12an
      "The surface mesh is intersecting or close to intersecting, making it difficult to create a volume mesh. Please adjust the mesh size or adjust the geometry to fix the problem."
      I am so close to getting this mesh done, only one part is failing. It was created in CREO Parametric and is a boundary blend. This is a ducted fan design with a pattern of a boundary blend for the blades. This error pops up for the originally blended blade only. When I look at the problematic geometry it is one element. What should I do to fix this element? I have no idea what is causing this or how to fix it.
      Were you trying to open meshing or mesh the geometry? n
  • The topic ‘Meshing Error’ is closed to new replies.
