Mesher Still Generates Internal Surfaces After Boolean Subtraction
    • a.y.al-wardi
      I’m working on a model where I’ve performed a Boolean subtraction (in DesignModeler) to remove internal components from a larger chamber. The Boolean appears to be successful as I can visually confirm the void region and there's only one solid body listed in the structure tree.
      However, when I open the geometry in ANSYS Meshing, the internal surfaces from the subtracted region are still being meshed, even though the volume was removed.
      What I have tried:
      • Performed Boolean subtraction properly (target body first, tool body second, “Keep tool body” unchecked)
      • Verified in section view that the void is present
      • Deleted/suppressed all leftover bodies
      • Confirmed that only one solid body exists
      • Exported the final result as a clean Parasolid (.x_t), and re-imported into a fresh Workbench project
      Why is ANSYS Meshing still picking up and generating mesh on internal surfaces after Boolean subtraction?
      Any suggestions on how to fully eliminate these would be appreciated.
      Please post some images.
    • NickFL
      You said that the void is still present. Does that not mean that you will have internal surfaces?
