March 26, 2024 at 8:41 am
dharanimoka
SubscriberWhile exporting a Rmxprt Induction motor model to ansys maxwell 2D, Ansys maxwell assumes the mesh to be SurfApprox_Bar and SurfApprox_Main.
While calculating the torque with the Maxwell Stress Tensor method using Brad and Btan values calculated from field calculator in MATLAB, I see that the torque calculated is different (less) than the value in Ansys Maxwell simulation result.
However, changing the mesh size using a legth based refinement, the torque value now calculated is almost the same as the one in Ansys simulation.
My question is, should the value of Brad and Btan change with the refinement of mesh size. If for a particular mesh size a torque is calculated in the simulation, shouldn't that value be the same as being calculated using the Maxwell Stress tensor method in MATLAB.Â
April 19, 2024 at 7:19 am
Navya Chode
Forum ModeratorHI Dharani Moka,
Your question is being answered in the below post. Please refrain from creating duplicate posts.
Mesh Size in Ansys Maxwell 2D SimulationsRegards,
Navya
- The topic ‘Mesh Size in Ansys Maxwell 2D Simulations’ is closed to new replies.
5964
1307
