Electronics
Electronics
Mesh Quality error
    • poonamchnd23
      while simulating the model in Ansys Maxwell, I am getting the error as "The quality of some mesh elements is not acceptable for solution. Please check the geometry for issues in the following location (in meters): X=0.158313, Y=-0.0836862, Z=0.000206528". When I locate the geometry, the error location is in the Air domain.
      I observed that this effect occur when I change the number of segment of cylinderical coil from 8 segments to 10 segments. i.e.
      8 segments = no error;    10 segments = error.
      what should i do? How to remove the error?
      As high number of segments are needed for the high accuracy results.
    • Harinath Vudumula
      Hello Poonam,
      Place a point at "location (in meters): X=0.158313, Y=-0.0836862, Z=0.000206528", It is w.r.t global coordinate system. Select the region and apply inside mesh settings and try running the model.
      Thank you.
