TAGGED: mesh, mesh-generation, meshing, modeling-and-meshing
September 25, 2020 at 11:31 am
manmorcan
SubscriberDear collegues,
I am doing my pre-doctoral project working simulating a kayak.
The problem I got is that, when I try to mesh, I got this:
September 25, 2020 at 3:21 pmRahul Kumbhar
Ansys EmployeenHere are some suggestion.nUse refined mesh sizing. nUse curvature size functionnturn on defeaturing and use defeature size bigger than thin faces so that it can ignore the sliver faces.nInsert Virtual topology object in the tree. Select the body, right click and generate virtual cells. It may simplify face representation if there are problematic faces.nSeptember 28, 2020 at 7:37 pmpeteroznewman
SubscribernDid you manage to close the surface model and get a solid body for the kayak before you created the Enclosure for the Fluid Domains?nDid you split the Fluid Domains at the waterline? That plane could also split the kayak.nThen you can use Shared Topology to put the kayak pieces back together.nNovember 18, 2020 at 4:02 pmmanmorcan
SubscriberDear Rkumbhar,nit was due to the solid.nnI fixed it in a design program and then introduced it again in Ansys and It worked!Thanks!!nViewing 3 reply threads- The topic ‘Mesh problem. Help please’ is closed to new replies.
4602
1510
1386
1209
