Mesh node limitation issue – Need to use fine mesh in the tread surface and coarsed mesh in the rest
    • ka423
    • Keyur Kanade
      You will need to use different sizing functions. nPlease have a look at nPlease check following videosnnAnsys Meshing Sizing:nhttps://www.youtube.com/watch?v=w4q6q8nKF3UnRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
    • ka423
      I checked out the video and the meshing done is in CFD not mechanical, which I was using at the moment. also the nodes count are above 60k~120k in the provided method. nif the mesh condition set by me is will work in the full licensed Ansys software that I can try, just need to clarify the condition set is correct or not.n
  • The topic ‘Mesh node limitation issue – Need to use fine mesh in the tread surface and coarsed mesh in the rest’ is closed to new replies.
