December 17, 2018 at 5:11 pm
ashiadarsh
SubscriberI would like to know how we can handle mesh interfaces in FLUENT Solver...my mesh was generated in pointwise..the problem is a conjugate heat transfer with a common interface between the solid and fluid domain...FLUENT identifies additional interface created in pointwise but i am unable to initialize the problem due to these additional interfaces...I know in space claim using the Share option before exporting the geometry into ANSYS meshing can automatically create connection in ANSYS Meshing and shadow regions in FLUENT solver...I would like to know how to handle this type of problem when using another meshing software like POINTWISE?
Adarsh
December 18, 2018 at 2:36 am
Keyur Kanade
Ansys Employeeyou may need to contact pointwise support for that. we dont have access to it.Â
from fluent perspective, you can go ahead and create interfaces. for the part which is overlapping, it creates interfaces. for the part of the boundary zone which is not overlapping, fluent creates additional wall boundary zones. if boundary zones are perfectly overlapping, these new wall boundary zones could be empty.Â
please go through help manual. i also inserting images from help manual.Â
if this helps you, please mark this post as 'is solution' to help others on forum.Â
December 18, 2018 at 4:01 am
ashiadarsh
Subscriber -
December 18, 2018 at 4:11 am
Keyur Kanade
Ansys Employeeif mesh interfaces are defined, you can proceed to your other set up and calculations.Â
December 18, 2018 at 4:49 am
Keyur Kanade
Ansys Employeeif this helps, please mark this as 'is solution' to help others on forum.Â
December 18, 2018 at 5:18 am
ashiadarsh
SubscriberThank you...I defined the mesh interfaces and the shadow region is also created in FLUENT..I am able to proceed to the setup and calculations now
Adarsh
February 13, 2020 at 2:39 pm
JavadAhmadi
SubscriberHello and thank you so much for all the information given by the authors here. I have just one question that recently I've faced, that is when we must tick the coupled wall options in the Interface Options? because during the solution of an example I did not check it out intentionally but there were not any discrepancies in the results. So it is really in my nerd that when would this could affect the results adversely. Thank you so much if somebody gives me enough information.
Bests,
Javad
April 15, 2021 at 7:30 pm
Mohannad Shahin
SubscriberI have a similar question. Did you manage to find an answer?nnThank you for your help.n
- The topic ‘Mesh Interfaces in ANSYS FLUENT’ is closed to new replies.
5154
1836
1387
1248
