September 28, 2024 at 11:35 am
aagalvez
SubscriberHello, good evening to everyone. Here is an update of case files being appended. I provided some gaps between domains (inlet, rotor, outlet) and came up with this (first picture). My problem now is the creation of mesh interfaces between domains. I tried to manually create mesh interface between the domains but zi am not sure if it is correct. If it is correct, can I proceed already to setup? Thank you very much. Also, I encountered a warning when I tried to write it as one case file in my solution.Â
October 1, 2024 at 12:16 pm
Forum ModeratorDuplicate  https://innovationspace.ansys.com/forum/forums/topic/overlapping-of-domains-during-appending-of-case-files/
- The topic ‘Mesh interface between domains, how to create?’ is closed to new replies.
Ansys Innovation Space
1103
1063
1050
952
