Mesh information and results export
    • gioeleg
      Dear all,
      I would like to export e.g. the strain energy results of a simulation in Ansys Mechanical, and I know how to do it; you can simply export a text file which contains the element number of the mesh and its corresponding strain energy value.
      The thing which instead I am not able to do is to export like a similar file for the mesh, where the same elements are linked to their position with respect to the coordinate system.
      Is there a way to do this?
      I would like to export these information to then work on them on Matlab. Hope someone could help me!
      Thank you in advance.
      Best regards
      Gioele
    • 1shan
      You want the node coordinates along with the node id's right? Inside mechanical go to file>options>export - Include node locations "Yes". You will find the coordinates along with the node id and strain result in the exported .csv file.
      Regards Ishan
    • gioeleg
      Yes thank you very much, that is exactly what I am looking for!
      Anyway I can only get the node coordinates when I export the total displacement, whereas when I am exporting the strain energy I do not get them... is it normal or there is something I can do about it?
      Thanks again in advance.
      Best Gioele
    • Ilia M
      Another problem is that there is an error in coordinates. Even if i set 10 significant digits in WB, I get a difference between the WB listing and APDL listing. For the same node, I get in APDL (via nlist):
      NODE        X                   Y                   Z
         797003  -0.161412972200        0.259275686600E-001  -0.151129722300E-001
      While in Workbench, I get this along with the displacements:
      Node Number    X Location (m)    Y Location (m)    Z Location (m)    Directional Deformation (m)
      797003    -0.1614129692    2.592756785e-002    -1.511297189e-002    6.799690588e-009
      This is not a round-off error, it's something else which I don't understand
  • The topic ‘Mesh information and results export’ is closed to new replies.
