October 23, 2018 at 7:44 pm
October 23, 2018 at 8:21 pm
peteroznewman
SubscriberIt's not necessary. The contact elements create a spiderweb of connections from nodes on the diagonal to nodes on the flat. You can have better control of how far out the contact element reaches and the evenness on the distance it reaches if you do make a conformal mesh, so the stress results could be improved in that way, but you could get the same effect by having smaller elements on the flat face.
If the Bonded Contact formulation is MPC, you can view the contact elements by clicking on the Solution Information folder and selecting the Graphics tab instead of the Worksheet tab.
Peter
- The topic ‘Mesh in connection’ is closed to new replies.
1587
1386
1242
