October 10, 2018 at 1:21 pm
rounaksingh
SubscriberHi,
I am trying to simulate in HFSS a model with object of 54mm largest dimension and another object with smallest dimension (thickness) of 0.00026mm. While running the simulation, I am getting following errors:
[warning] Model has very thin thickness body (9:13:43 AM Oct 10, 2018)
[error] Surface Mesh Generation Failed. (9:13:43 AM Oct 10, 2018)
[error] Simulation completed with execution error on server: Local Machine. (9:13:43 AM Oct 10, 2018)
I am getting this error regardless of the machine I am running simulation on.
Is there a way to solve this error? or any alternate way. I cannot remove the object with smallest dimension because it affects the simulation.
Thanks! -
May 2, 2020 at 11:10 am
choudary
SubscriberHello rounaksingh,
Had you found solution of your problem?
I am also facing the similar issue. I have tried many things but without success.
Would you like to share your solution? It would be a great help.
Many thanks.
May 3, 2020 at 12:02 am
rounaksingh
SubscriberTry changing the units to lower like mm or um in the Modeler menu. It may work. One of my design worked by doing that.
May 13, 2020 at 10:00 am
choudary
SubscriberThank you for your reply.
- The topic ‘Mesh generation fails in HFSS – “Model has very thin thickness body”’ is closed to new replies.
3572
1188
1076
1063
952
