Preprocessing
Preprocessing
Mesh Generation error in Ansys Fluent
    • Sohil1994
      I am trying to mesh an assembly of a solar air heater (shown in the pics below).  Just FYI, the heater is made up of a wooden box with a glass cover. Air flows through the convoluted pipe. I am trying to conduct the CFD simulation for the same.
      So far, I imported the geometry from Solidworks into Ansys and tried to apply the default mesh, but it is giving me the following error:
      " Patch-conforming tetrahedron mesh failed because of an edge intersection in the boundary mesh" (refer the last pic)
      Should I play with the mesh settings? Any insights would be greatly appreciated!
      Thanks in advance!
    • Keyur Kanade
      open solidworks geometry in design modeler first.
      use sharetopology.
      check if geometry has any errors using tools - analysis tools - fault detection.
      if any errors then correct them and then go to meshing.
      https://www.youtube.com/watch?v=IO4ZtwZdD2I
      https://www.youtube.com/watch?v=sZIX3CJkWBE
  • The topic ‘Mesh Generation error in Ansys Fluent’ is closed to new replies.
