MESH FOR HELICAL STRAKE
    • kingdsystems
      I am working on the simulation of fluid pasted various cylindrical body such as smooth cylinder body, helical straked cylinder body and cactus shaped cylindical body. I am trying to compare their effectiveness in mitigating vortex shedding and drag. The structure all have the sample diameter (0.5m) and domain (5m x 15m).
      The smooth cylindrical body gave an expected plot showing the lift and drag curve but the other structures didn't. I don't know if i am correct or not as i am relative new in fluent with respect to this.
      For the smooth structure, i used the edge sizing and inflation mesh (inflation option: First inflation layer thickness, first layer height: 0.03m, Maximum layer: 40 and growth rate: 2.5). I applied the same mesh to the other structures but i don't know if the result i am having are good.
      Please i need advise on the best mesh methods and other settings to achieve a good result on the other structures.
      Below are my contour plots for the structure.
      SMOOTH STRUCTURE
      CACTUS SHAPED
      HORN-STRAKED
      HELICAL-STRAKED
      Those contours look a little odd. How good is the mesh quality? What is the domain inlet velocity?
    • kingdsystems
      Thanks Rob for your prompt response.
      The inlet velocity for each of the structure was taken to be 0.021m/s.
      Below are the mesh for each of the structures.
      SMOOTH STRUCTURE
      CACTUS SHAPED STRUCTURE
      HORN-STRAKED STRUCTURE
      HELICAL-STRAKE
      Please, if my meshes are wrong, can you help with best way to go about doing a good mesh.
      Thanks
      I'm not even sure how you've managed to create a mesh like that. Have a look in the Mesher Help and do the tutorials.
  • The topic ‘MESH FOR HELICAL STRAKE’ is closed to new replies.
