April 16, 2021 at 10:53 am
sunmix6
SubscriberHello everyone,nI'm using the ICFD of LS-Dyna to simulate the forming of fibrous composite. However, there will always be errors after running for a period of time:nError 120003 (ICFD+3). Possible surface collapse.nI don't know what caused the error. Re-Meshing has been turned on and there's no duplicate nodes.nIf anyone knows why, can you help me? Thank you so much.nn -
May 2, 2021 at 5:17 am
tslavik
Ansys EmployeeThis error usually happens when two fluid surfaces intersect and come into contact with each other. This will create an invalid fluid mesh i.e "a mesh surface collapse". The key here is to find in which region this is happening (there is a  file which dumps the surface mesh : icfd_tmp_sm.k which  often helps) and to define a contact with offset (See *CONTACT) between those two parts such that no penetrations are allowed.
May 3, 2021 at 5:40 pm
sunmix6
SubscriberThank you so much for your help. I have checked icfd_tmp_sm.k and confirmed the contact failure area. It occurs in self-contacting parts.
Do you mean that the "offset" refers to a contact type similar to TIED_NODES_TO_SURFACE_OFFSET? After consulting some relevant documents, I found that this type of "TIED" contact does not seem to apply to self-contact situations. Do you have any suggestions for self-contact penetration in ICFD? Thank you!
October 24, 2022 at 8:23 pm
Md Zunayed Habib
SubscriberI am experiencing the same issue. Did you get a solution?Â
- The topic ‘Mesh error in LS-Dyna’ is closed to new replies.
Ansys Innovation Space
- APDL, memory, solid
- Meaning of the error
1461
1272
1124
