TAGGED: acp, acp-pre, composite-material, static-structural
February 6, 2022 at 5:29 pm
Dioser
SubscriberHey everyone,
I am using Workbench with ACP pre to set up composite material, stackups and directions for an aircraft structure, as shown in the pictures below. For reference, I used this great tutorial from YT, just adapting the methods to my problem:
February 7, 2022 at 4:10 pmGovindan Nagappan
Ansys EmployeeCheck the units in ACP and also Mechanical
Also check the units in the project schematic:
Did you assemble meshes in Static structural system? Try using a new static structural system and send the mesh from ACP. See if it fixes the issue
If not, your project may have corrupt data that could be causing this issue
Viewing 1 reply thread- The topic ‘Mesh error after setting up composite in ACP pre’ is closed to new replies.
2863
970
851
599
591
