Preprocessing
Preprocessing
Mesh control question
    • mart9203
      Hi
      Why doesn't the face sizing apply to the whole face?
    • RK
      It is not clear from the picture you have inserted. Please zoom out a little and then take a screenshot so that we can get a better picture of the geometry.
      Thanks,
    • mart9203
      The black stuff is a very fine mesh. It should have continued along, but here is a patch in the middle which doesn’t get affected.
    • Keyur Kanade
      can you please split the geometry so that the face is splitted in two or three faces.
      then define sizing for these faces.
      Please see help manual for more details about these commands.
      Keyur
      If this helps, please mark this post as 'Is Solution' to help others.
    • mart9203
      Where should I split it. in the coarse mesh, in the fine mesh or on the transition?
    • mart9203
      If anyone encounters similar problems. What caused problems for me was a contact sizing fairly close on the opposite side. Suppressing that solved it.
Viewing 5 reply threads
  • The topic ‘Mesh control question’ is closed to new replies.
