Mesh- Beam Element
    • help_me
    • Govindan Nagappan
      You will have to use APDL commands to modify T and N.
      Cross sections can be defined in geometry editor(DM, SCDM) or Mechanical.
      For T and N, right click on line body under geometry branch in Mechanical and insert command. Use secdata command to overwrite the defaults.
    • help_me
      thanks for ur comment. Actually, I've already tried it, but it doesn't work
      Code:
      SECTYPE,matid,Beam,CSOLID
      SECDATA,1,15,5 % R, N, T
  • The topic ‘Mesh- Beam Element’ is closed to new replies.
