May 7, 2020 at 9:10 pm
pilot66
SubscriberHi,
I'm currently working on a project where analyzing Aluminum beam under load, causing bending and torsion. Since the geometry is relativley simple, I tried to build up an appropriate multi zone mesh, but the problem with multi zone mesh is, that Ansys cannot calculate automaticly if results (stresses) are converging. Trying to validate the results I solved the same problem with auto (tetrahedral) mesh. Deformation seems to be close to the solution with previous mesh, but I have issue because normal stress (x-direction) does not converge and are far from results with multi zone mesh.
I assume the problem is, that critical stress point is close to area with zero displacement condition(area B on the picture has fixed y direction) maybe there is a problem with singularities?
The goal of the problem certainly is to find out whether max. stress in every single part of the beam is below critical (yield) stress or with other words if the beam is not plastically (permanently) deformed.
- The topic ‘Mesh and convergence issue’ is closed to new replies.
3024
971
858
836
777
