TAGGED: adapt, adaptive-mesh, fluent, mesh-adaption, mesh-adaption-fluent
March 22, 2024 at 6:13 pm
vedama
SubscriberI have a simple 2D case that I'm running grid adaption on. The image below is a zoomed in image near the inlet.
This next image is the set of marked cells in that same region. Note how the first "column" of cells are not being marked.
However, when I adapt, cells that aren't being marked are being adapted, as in the image below. Look at the first "column" again and compare the above 2 images with the image below.
Why is this happening? This is causing divergence issues. The solution is blowing up and giving garbage values.
March 25, 2024 at 10:02 am
Forum ModeratorI'm slightly intriqued as to how you've got such a mix of quad & tri cells, but that shouldn't be an issue.Â
What are you using for the adaption criterion?Â
March 25, 2024 at 2:36 pm
vedama
SubscriberI'm using gradient and curvature of density across multiple iterations. This is the 6th cycle of adaption. I have max refinement level set to 5
March 25, 2024 at 2:48 pm
Forum ModeratorWhich may mean you've got holes in the register because that's what the gradients say. If you look at the contours how do they look (before it fails)?
March 25, 2024 at 2:57 pm
vedama
Subscriber-
March 25, 2024 at 3:04 pm
vedama
SubscriberJust to be clear, it is a high-speed flow case so the contours should look clean and smooth, especially at the inlet. I'm also using second-order upwind scheme and AUSM inviscid flux type so really, everything should be going downstream. I have a really fine un-adapted case that reflects this accurately.
March 25, 2024 at 3:06 pm
Forum ModeratorI have no idea re the inlet as I have no idea what is set. Or what you're modelling.Â
Registers of gradient will trigger only when that criterion is met. So, if you have a small patch with lower gradient you may have a "hole" in the register. That then causes odd mesh adaption. If you've not set the coasening criterion (assuming a moving shock) the it's anybody's guess how the mesh will finish up.Â
March 25, 2024 at 4:12 pm
vedama
SubscriberI do not have a coarsening criterion currently.
I'm trying to understand your point about holes just so I can get a better understanding of the functionality. My current register looks for density gradients/curvatures in the solution and marks cells for adaption based on a specific set of minimum threshold values. If the cell values are above this threshold value, they should adapt. If the cell values are lower as stated/shown by the marked cells, what exactly is happening to cause the cell to be adapted?
March 25, 2024 at 4:44 pm
Forum ModeratorOK, re the gradient. Let's assume a chess board. We'll adapt for greyscale gradient, so only pick the cells either side of the boundary. That should pick up all cells around the black square, but may omit the corners as they're diagonal to another black square. If we repeat, then we'll just pick the smaller cells on the black-white boundary. However, in your case the solution is evolving so the position of the higher gradients moves, and if the gradient is better resolved in the previous steps it's value is now low enough to not be picked. The register is doing exactly what you told it, hence plotting the values to see what's going on.Â
March 25, 2024 at 5:00 pm
vedama
SubscriberRight, but according to my criterion, the first column of cells is low enough that it is not being marked. But it's still being adapted, and you said it's because of a "hole" in the register. How does the hole relate to the chessboard analogy?
March 25, 2024 at 5:23 pm
Forum ModeratorThe lowest cells aren't being marked - there's a gap to the grey line on the image.Â
March 25, 2024 at 5:33 pm
March 25, 2024 at 5:41 pm
Forum ModeratorOnly one cell's been picked up. That's due to the adjacent adaption, you can't have multiple adaption layers next to unadapted mesh.Â
March 26, 2024 at 3:44 am
vedama
SubscriberOk yes that makes sense. Thank you!
- The topic ‘Mesh adaption of cells that are not being marked’ is closed to new replies.
5819
