October 29, 2020 at 4:22 am
Lugia_06
SubscriberHi everyone,
Is there a way to selet the cell region only by the range of aspect ratio and only adapt in x direction?
October 29, 2020 at 7:37 amDrAmine
Ansys EmployeeBulk (far from walls ) adaption will always be isotropic. Anisotropic adaption is available but this require the surface/wall where to start from.nOctober 29, 2020 at 5:35 pmLugia_06
SubscribernThank you for your reply. Another point quite sure about is how to create a register by aspect ratio. Under field value of mesh, it does not seem to have that option, is there any alternative option combinations that could do the same?nBest regards,nLugia_06nOctober 29, 2020 at 5:42 pmLugia_06
SubscriberWhere can we find the anisotropic adaption on ansys 2020 R1(or later)?nOctober 30, 2020 at 7:35 amDrAmine
Ansys EmployeeIn the same menu nnOctober 30, 2020 at 7:38 amDrAmine
Ansys EmployeeThe anisotropic adaption will be much more powerful in the next upcoming release! Stay tuned.nOctober 30, 2020 at 11:28 pmLugia_06
SubscriberThank you !nOctober 31, 2020 at 9:42 amLugia_06
and everyone,nI am trying to refine an 2D oulet zone(region_1) in x direction to lower the aspect ratio of the cells right next to the axis. However, the ansys tutorial 38.4.1. Limitations of Anisotropic Adaption (https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v201/en/flu_ug/x1-191300028.9.1.html) says this is only allowed for 3D. Is there a way to adapt a 2D quad cells?nBest regards,nLugia_06n
November 7, 2020 at 2:27 amLugia_06
SubscriberWill there be 2D anisotropic adaption function in the next release of Fluent? When is the release date? I am looking forward to it!nNovember 7, 2020 at 7:01 amLugia_06
SubscriberIs there any alternatives for 2D anisotropic adaption in Fluent? All I need to do is just changing the aspect ratio in the outlet cell zone, but the mesh module always gives unstructural mesh around the corner of the outlet orifice or far back at the inlet zone. I used face meshing for the whole geometry and edge sized the outlet bit, could anyone explain why the quad mesh disabled at the orifice fillet and how I should fix this issue? From the look of it the edge sizing at the outlet should not be related to the orifice right?nOutlet element size 9e-6 mn
Outlet element size 8e-6mn
n
November 7, 2020 at 7:02 amLugia_06
SubscriberFor the element size I meant the outlet element size in x directionnViewing 10 reply threads- The topic ‘Mesh adaption by aspect ratio field variable’ is closed to new replies.
5639
1885
1403
1303
