September 9, 2024 at 7:51 am
malvi.mitesh07
SubscriberHello
I am doing analysis of a spiral bevel gear set to check the contact pattern. I get all the contact stresses on the gear flank. However, I want to show the stresses that move as the gear pair rotates in one photo / at once to show the overall Area that the gear flank experiences under load. I tried to take screenshots of the results at different load steps and use photo editing softwares to club them together but wanted task if there is a quick way directly with ansys.
September 10, 2024 at 1:05 pm
danielshaw
Ansys EmployeeDid you consider using Solution Combinations to combine the results from different result sets?
Ansys Innovation Space
1113
1063
1050
952
