November 22, 2023 at 9:01 pm
lidianne.pinto
SubscriberI modeled a Chiral metamaterial cell in the space claim and considered that the surfaces are merge. However, in the compression analysis (Workbench), the circular surface is displaced from the other surfaces.
Then, I considered bonded contacts between the surfaces and the same thing happened.
The geometry has the following errors:
But I don't know how to solve them. I divided the circular surface into two geometries and it didn't solve the problem.
Can you help me, please?
Thanks!
November 23, 2023 at 3:34 pm
Rahul Kumbhar
Ansys EmployeeHi, You can split circular face at the edges of flat faces touching them. Then you can use share topology.
November 23, 2023 at 6:09 pm
- The topic ‘Merge in space claim and bonded contacts doesn’t work for chiral metamaterial’ is closed to new replies.
1565
1386
1242
