July 2, 2021 at 12:37 pm
Scat
SubscriberI am trying to run a large FDTD simulation on a server. According to the memory report, 164MB is required for initialization and mesh, and 299.404GB is required for running the simulation. I am trying to run this simulation on a server that has 390GB of memory, however when I run it the memory of the server gets consumed almost immediately during the meshing phase, after which it starts using up the swap space after which I am forced to kill the process before it uses up all the swap space...
How come the memory report indicates that only 299GB of memory will be required, however when I try to run the simulation it seems to use more than 500GB during the meshing stage? And can this be fixed?
July 6, 2021 at 10:54 pmGuilin Sun
Ansys EmployeeThe memory check is an estimation, and how your computer allocates the memory for a specific simulation file will strongly depend on the hardware (chips) and software (os) as well as background running programs. I am not sure the memory of 390GB in your computer is from one core or several different cores, and how those cores communicate/coordinate to handle the meshing and simulation. As far as I know, one core has limited memory. You may check how many processes you have specified in the "Resource" tab:
If you specified fewer processes and their total memory is not enough it will free your computer. Please check and test. if problem still exists, please post some screenshots here.
July 20, 2021 at 8:16 pmScat
SubscriberDear Gsun, thanks for your message.
The system I am trying to run this on has 28 cores, however I had the resources setup at 32 cores (see screenshot below). I believe this shouldn't be a problem with the memory?
I believe the problem is that during the meshing stage Lumerical uses a lot more memory when using the conformal meshing stage. I have found that also with smaller simulations (~200GB), Lumerical uses significantly more memory than reported in the memory report (>350GB). However when going into the running stage of the simulation the total memory usage is almost exactly the value reported in the memory report.
I ended up running the simulation using the staircase mesh, which worked (albeit it taking a very long time to finish).
July 20, 2021 at 11:28 pmGuilin Sun
Ansys EmployeeConformal meshing needs extra calculation and it was added later, so the memory estimation may not well consider it. I will let related person know this.
July 21, 2021 at 10:31 pmGuilin Sun
Ansys EmployeeThis is unfortunate. I will try to dig more about it and reply you if I have the answer. My guess is, the extra memory from conformal meshing is not counted as it was developed well after the memory estimation.
Viewing 4 reply threads- The topic ‘Memory report FDTD inaccurate’ is closed to new replies.
5664
1890
1414
1304
