April 29, 2024 at 12:52 pm
Luca Dannemann
SubscriberHello everyone,Â
does anyone have experience with simulating in a loop? I am running many (>1000) simple simulations within an optimization algorithm. I use PyMapdl for this. With each simulation the required RAM in Python increases. If I do not run the simulations, the problem does not occur. Enclosed is a highly simplified Psyeudocode where the problem also occurs. Even starting and closing Ansys in each run does not solve the problem (apart from a considerable increase in runtime).import osfrom ansys.mapdl.core import launch_mapdlpath = os.path.abspath(__file__)directory = os.path.dirname(path)temp_dir = os.path.join(directory, 'temp_ansys')if not os.path.exists(temp_dir):Â Â os.makedirs(temp_dir)mapdl = launch_mapdl(nproc=4,run_location=temp_dir, override=True)def calculate_energy():Â Â mapdl.clear()Â Â mapdl.prep7()Â Â mapdl.blc4(0, 0, 1000, 1000)Â Â mapdl.blc4(1000, 0, 1000, 1000)Â Â mapdl.aglue('ALL')Â Â # BCÂ Â mapdl.ksel("S", "LOC", "X", 0)Â Â mapdl.ksel("A", "LOC", "X", 1000)Â Â mapdl.ksel("R", "LOC", "Y", 0)Â Â mapdl.dk("ALL", 'UX', 0)Â Â mapdl.dk("ALL", "UY", 0) ÂÂ Â mapdl.allsel()Â Â mapdl.clear()Â Â return 1for i in range(0,1000):Â Â a = calculate_energy()Â
April 30, 2024 at 10:02 am
mjmiddle
Ansys EmployeeTry posting over:
https://discuss.ansys.com
April 30, 2024 at 10:14 am
erik.kostson
Ansys EmployeeOur colleagues are helping :
https://github.com/ansys/pymapdl/discussions/3041
Closing here
Erik
- The topic ‘Memory Leak PyMapdl’ is closed to new replies.
