Memory Issue in ANSYS static structural mechanical APDL
    • Faryal
      I am using 24GB CORE I3 pc. I am simulating a hollow cylinder having cross beams. The model is 30 mm in diameter. 0.1 mm mesh size, static structural using workbench mechanical APDL IS giving me memory errors.
      Do you get memory errors if you use 1 mm mesh size?
    • Faryal
      No there are no memory errors for 0.5 mm.
    • Faryal
      I have another PC OF 32 GB RAM having gtx 1050. But gtx1050 is incompatible with ANSYS and when i change to iterative from direct in solver output then it automatically selects direct solver when i see solver output.
    • Faryal
      Does ANSYS 19.2 solves this issue?
    • Faryal
      *** FATAL ***                           CP =     909.625   TIME= 17:205
       This model requires more scratch space than available.  The program has
       currently allocated 38633 MB and was not able to allocate enough
       additional memory in order to proceed.  Please increase the virtual
       memory on your system and/or increase the work space memory and rerun
       the program.  Problem terminated.
       ERROR: Slave process(es) with rank(s) 1, 2, 3 have encountered a FATAL error.
       The information below was gathered from the file*.out output file(s).
       Please review the slave process output file(s) listed below for more
       details on this error.
       Slave Process Output File .file1.out:
       *** FATAL ***                           CP =     231.609   TIME= 17:205
       currently allocated 15385 MB and was not able to allocate enough
       Slave Process Output File .file2.out:
       *** FATAL ***                           CP =     237.984   TIME= 17:205
       currently allocated 13666 MB and was not able to allocate enough
       Slave Process Output File .file3.out:
       *** FATAL ***                           CP =     249.734   TIME= 17:205
       currently allocated 13527 MB and was not able to allocate enough
      No, ANSYS 19.2 will have the same issue.  It will be best if you can install more memory in the computer.  Even if you do, there will just be a higher limit. You have to learn to make a mesh that is coarse where the gradient and stress is low, and have a fine mesh where the gradient and stress is high. That is what some of the Mesh Controls such as Body Sizing - Sphere of Influence allows you to do.  You have to put a coordinate system at the location of high stress.
Viewing 6 reply threads
  • The topic ‘Memory Issue in ANSYS static structural mechanical APDL’ is closed to new replies.
