Mechanical scripting
    • s310413
      Hi everyone, I'm trying to automate a simulation and I need to write the input file (.dat) of a static structural analysis. In mechanical ACT console I tried with the command
      ExtAPI.DataModel.Project.Model.Analyses[0].WriteInputFile('filename')
      but I don't know if and where it is saving the .dat file. Does anyone know where the file is saved and eventually how can save it in a desired folder? Thanks
    • erik.kostson
      Hi so in file name you give also the directory path so e.g. , say it is in D drive and folder called Test:
      See here how it is done:
      https://discuss.ansys.com/discussion/142/how-can-i-write-an-input-file-through-act
      All the best
      Erik
  • The topic ‘Mechanical scripting’ is closed to new replies.
