February 17, 2021 at 5:57 am
chenqingsen
SubscriberIs there an example of mechanical result workbench showing calculated data? I calculated the data of each load step for each node in ACT, which needs to be displayed in the worksheet.
I have asked this question in Learn hub,but no one answer it.
February 18, 2021 at 1:10 pmpeteroznewman
SubscriberWhat ACT are you using?nWhat do you mean 'calculated data'? Results requested in Mechanical such as deformation or stress include a Tabular Data window.nnFebruary 19, 2021 at 2:03 amchenqingsen
Subscriber@chenqingsen What ACT are you using?What do you mean 'calculated data'? Results requested in Mechanical such as deformation or stress include a Tabular Data window./forum/discussion/comment/107232#Comment_107232
nI am doing ACT plug-in development to post the result. I calculate a few of result dates in ironPython scrip and I need to show them in worksheet window or tabular date windownViewing 2 reply threads- The topic ‘mechanical result worksheet to show data using ACT’ is closed to new replies.
Innovation SpaceTrending discussions- The legend values are not changing.
- APDL, memory, solid
- Meaning of the error
Top Contributors-
4162
1487
1318
1170
