TAGGED: ansys-license, ansys-mechanical, crash, elastic
June 13, 2022 at 12:09 pm
gioele.genazzi
SubscriberHello,
our company recently changed its license type to an Elastic one, and since then Mechanical began to not start. Whenever I try to run it, in the Workbench tab there is always the red dot with the "Busy" writing near it (in the bottom left side of the window) and it does not start even after a long time. Checking in the Task Manager then you can see 0% of work on the CPU.
What could this be? I don't think it should be caused by the license... I already tried re-installing everything.
Thank you in advance for any help.
Best,
Gioele -
June 14, 2022 at 6:09 pm
federico.mazzotta
SubscriberHi ! I have a similar problem. After a simulation mechanical crashed and from that moment I'm not anymore able to launch Workbench. However, if I'll launch mechanical standalone it works.
Thank you ! -
June 15, 2022 at 1:21 pm
George Karnos
Ansys EmployeeIf your Company is using commercial licenses, I would suggest to log a Service Request on the
ANSYS Customer Portal and a Support Person will contact you directly.
- The topic ‘Mechanical is not starting’ is closed to new replies.
Ansys Innovation Space
1328
1163
1090
1014
