April 2, 2020 at 8:49 pm
akul99
SubscriberHi
The problem is that the geometry does not load into Mechanical.
The 2 error messages I get after Mechanical is closed automatically is the following:
1. Type: Error!
Message: Unable to set display parameters property in Mechanical Either the application crashed or Workbench lost communication with it.
2. Type: Warning!
Unable to initialize addins in Mechanical. Either the application crashed or Workbench lost communication with it (No connection could be made because the target machine actively refused it 127.0.0.1:49893).
In particular, what happens is that I double click on Mechanical and stays for a while showing the empty bars of the geometry loading process on the screen (does not start loading), before showing the message bellow and automatically closing mechanical:
Any help would be greatly appreciated. Thank you.
March 7, 2021 at 12:55 am
sofla9
SubscriberHi, I have the same problem. Could you solve it?n
- The topic ‘mechanical error’ is closed to new replies.
3832
1414
1220
1101
1015
