Mechanical database automatically saved when Mechanical is closed
    • vganore
      Why is the Mechanical database automatically saved when Mechanical is closed?
    • Arun Kumar
      When a Mechanical session is closed, the database is automatically saved to ensure that if it is reopened in the same Workbench session the latest state is restored. For example, if you rename a Mechanical object from A to B; and then close and reopen Mechanical in the same WB session (without saving the project), the object name will be B.
  • The topic ‘Mechanical database automatically saved when Mechanical is closed’ is closed to new replies.
