TAGGED: #explicit-dynamics--#solver-#autodyne, #mechanical-#workbench, ansys-explicit, ansyswbdumpfile.dmp, ansyswbu.exe, ansysworkbench, dmp, explicit, explicit-dynamic, explicit-dynamics, explicit-dynamics-solver-autodyne, installation, mechanical, solution-problems, solver-ansys-mechanical, solver-error, student-version
January 14, 2025 at 8:10 pm
christof.schreijaeck
SubscriberHey there,
ich need Help. Every time i want to start the solver on my explicit dynamics project, a problem with the AnsysWBU.exe appears and it crashes.
I already tried several different versions of Ansys with the same result. Also clearing the %Temp%-Folder and new installations didn't helped.
Unfortunatly I'm not able to get any Information out of the Dump-File by myself. I'm totally lost and don't know what the problem could be.
I have no problems with the static-mechanic-solver.
I would appreciate any kind of help a lot. Ansys v24.2 Student
January 16, 2025 at 5:58 am
Subhash Tadala
Ansys EmployeeÂ
Hi Christoff,Â
The possible reasons would be as follows:
1) Not Updated Graphics driver : Please update the preferred graphics driver to the latest version.
2) Possibly corrupted project : You can recover the project How to restore the corrupted project in ANSYS Workbench? – Ansys Knowledge
3) Model size and memory requirement: Can you give a comparision between the number of nodes/ total degrees of freedom between static structural model and explicit dynamics model ?? Have you tried once to open the same model in static structural and facing the same issue ?
4) Monitoring the Task Manager : Can you monitor task manager and check the RAM usage while the mechanical is opening ?Â
5) Â Scratch solver files directory: https://innovationspace.ansys.com/forum/forums/reply/307018/
Additionally, you can also find some useful information in the following thread https://innovationspace.ansys.com/forum/ansys-bing-search/?q=ansyswbu.exe%20encountered%20a%20problem%20explicit%20dynamics&offset=0&searchVertical=web
 Please let us know if it helps.
Thanks,
Subhash Tadala.
5154
1836
1387
1248
