May 29, 2024 at 7:26 pm
yihong.cheng
SubscriberI have two independent bodies with one shared interface. I want to use different meshing size for these two bodies. However, at interface the meshing is not conformal. How could I fix it?
May 30, 2024 at 9:22 am
Aniket Chavan
Forum ModeratorPlease use Shared topology in the upstream geometry editor. Depending on which tool you are using you can check either:
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v241/en/discovery/Discovery/user_manual/Shared_Topology_intro.htmlhttps://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v241/en/wb_dm/dm3dSharedTopology.html
-Aniket
June 3, 2024 at 5:41 pm
yihong.cheng
SubscriberÂ
Hi Aniket, thanks for the reply.
By using this shared topology, I can get conformal meshing. However, I still need the interface so thermal contact conductance can be implemented. I guess the question is at interface there are two sets of meshing belonging two body 1 and body 2, and the meshing/nodes are identical.
June 4, 2024 at 3:19 pm
Aniket Chavan
- The topic ‘Mechanical conformal meshing for two bodies’ is closed to new replies.
