July 20, 2021 at 12:51 pm
CamMac98
SubscriberHi, I've been working on a static structural project for a few weeks now and have run into a strange problem. The model itself is replicating a multi step forming process (two dies deforming a part one after another). So essentially I have 4 load steps: die 1 compression, unloading, die 2 compression, unloading. On all load steps I've been using auto time stepping. The strange part begins in step two when die 1 breaks contact with the part and no compression is occuring... Only the movement of die 2 into position. during this time force convergence drops, yet the time step decreases to the lower limit I set instead of increasing. When load step 3 begins there still is not an initial contact meaning overal force is still very low, yet time increment will jump up to the initial value I set then decrease again. Does anybody know why this might be happening? I am using displacement controls on the die so I don't believe rigid body motion is an issue
July 23, 2021 at 2:50 pmViewing 1 reply thread- The topic ‘MECHANICAL: Auto time stepping is decreasing to minimum step size when force convergence is low?’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
Top Contributors-
3887
1414
1241
1118
1015
