December 6, 2020 at 2:43 pm
rishabh_aga
SubscriberI recently installed Ansys Student Version and when i try to run the APDL launcher and click on the run button, the command window pops up and shows me the error as Check Firewall, even though all my firewalls are down. Please Help me.
December 17, 2020 at 2:26 pmLuis Silveira
Ansys EmployeeYou are most likely connected to VPN. nDo the following: nnSTOP your local License Manager nEdit the ansyslmd.lic file under the C:\Program Files\ANSYS Inc\Shared Files\Licensing\license_files directory and change the hostname to the loopback  (127.0.0.7 ):nfrom nSERVER DESKTOP-H5PIUV5 FLEXID 1055nTO nSERVER 127.0.0.1 FLEXID 1055nSave the license file. Restart the ANSYS LMnnEdit the ansyslmd.ini file and set the same information there and add the following variables (It should look like the following): nSERVER=1055@127.0.0.1nANSYSLI_SERVERS=2325@127.0.0.1nANSYSLI_TIMEOUT_FLEXLM=15nANSYSLI_FLEXLM_TIMEOUT_ENV=15000000nnTest the application again. nPlease let us know if this helps.nDecember 17, 2020 at 2:28 pmLuis Silveira
Ansys EmployeeCORRECTION ON THE LOOPBACK INFOnSTOP your local License Manager nEdit the ansyslmd.lic file under the C:\Program Files\ANSYS Inc\Shared Files\Licensing\license_files directory and change the hostname to the loopback  (127.0.0.1 ):nJanuary 14, 2021 at 5:50 pmJanuary 14, 2021 at 6:17 pmViewing 4 reply threads- The topic ‘Mechanical APDL Launcher not working’ is closed to new replies.
5734
