September 10, 2024 at 9:22 am
jonas.santin
SubscriberI've run a simulation in Ansys Mechanical 2024, but the deformation plot isn't working correctly. When I use the "adjust to visible" option, the deformation values in the legend convert from mm to m. For example, instead of showing 0.54 mm, it displays 0.00054 m. Does anyone know how to fix this?
Thanks
September 10, 2024 at 9:28 am
Erik Kostson
Ansys EmployeeHi
Which version are you using?
If it is R1, download and install R2 (2024).
All the best and perhaps that resolves it
Erik
September 10, 2024 at 9:35 am
September 10, 2024 at 9:37 am
jonas.santin
SubscriberHi Erik,
Thank you for your response. Yes, I'm currently using R1.I'll check if the issue is resolved with R2.
September 10, 2024 at 10:07 am
Erik Kostson
Ansys EmployeeYes do that - should be ok in R2.
- APDL, memory, solid
- Meaning of the error
1482
